neue Basecamp Version verfügbar ....
Re: neue Basecamp Version verfügbar ....
#26 Beitrag von Frank@Pfalz »
Update auf Basecamp 4.2.3 ist verfügbar
innerhalb BaseCamp: Hilfe --> nach Software-Updates suchen
Notes:
Windows XP Service Pack 3 or later is required.
.NET framework 3.5 SP1 is required. A current version of .NET will be installed if needed.
Windows Media Player 11 or greater is required (a free download from Microsoft).
1 GB of system memory is required, 2 GB of system memory is recommended when using BirdsEye Imagery or Garmin Custom Maps.
A video card that supports OpenGL version 1.3 or later is needed to enable the 3D view.
If you experience problems when interacting with the map views, please make sure that you have installed current video card drivers.
BaseCamp will recognize all MapSource products except BlueChart.
BaseCamp does not work with serial GPS devices.
Changes made from version 4.2.2 to 4.2.3:
Fixed imported files not creating lists in the proper place
Added ability to remove and delete user data when a list folder is selected
Added keyboard arrow key handlers to the geotagged photo properties dialog
Added support for joining tracks when the track point timestamps don't line up
Added support for a transparent color in Custom POI files
Added export of waypoints, routes, and tracks to KML
Added reading of fitness courses from Edge devices, these are converted to tracks
Improved quick search responsiveness, speed of searches, and usability
Improved Trip Planner UI display refresh and sizing behavior
Change so that 'Install Maps' and 'Check for device software updates' menu items are always visible and enabled
Change to recalculate the route if needed when the route properties dialog is hidden, not just when selection changes
Change so that list folders aren't required to have unique names in the same parent folder
Fixed issue with junction view information in routes not being calculated correctly, may not work on certain older devices
Fixed issue with track stats not updating after editing the track
Fixed various issues with Trip Planner
Fixed issue with reading some map files from newer PND devices
Fixed issue with some drag/drop operations
Fixed rounding of dimensions in truck and RV routing options
Fixed issue with displaying many error dialogs if a device is unplugged during a transfer
Fixed drag/drop of an Adventure from find results into Trip Planner
Fixed issue when creating a route from a Yelp find result that failed to geocode
Fixed issue with fitness data not being preserved when sharing data with Garmin cloud storage
Lumi
#27 Beitrag von Lumi »
Klasse ich muß eh noch 2013.41 deinstallieren, falls also BC immer noch mit verschwindet.
GS 2015
#28 Beitrag von Frank@Pfalz »
Lumi hat geschrieben:falls also BC immer noch mit verschwindet.
geht das mit dem internen Update nicht ;-)
den Download gibt's >> hier << für Windows User
Lumi
#29 Beitrag von Lumi »
Schon gemerkt
es können wieder ganze Ordner mit den darin liegenden Listen in "Meine Sammlung" gezogen werden.
Super
GS 2015
#30 Beitrag von Frank@Pfalz »
Mac-Users only: > hier klicken < um BaseCamp 4.2.3 herunterzuladen
#31 Beitrag von Frank@Pfalz »
Update auf Basecamp 4.2.4 (für Windows) ist verfügbar
BaseCamp 4.2.4 ist als Update verfügbar ( innerhalb BaseCamp: Hilfe --> nach Software-Updates suchen)
oder als Download über http://www8.garmin.com/software/BaseCamp_424.exe.
GARMIN hat geschrieben:Änderungen in der Version 4.2.4:
Changes made from version 4.2.3 to 4.2.4:
Fixed error when deleting the last track point in a track
Fixed 'Arrive Continue' guidance issue on zumo 660
Fixed address search issue when running in languages other than English
Fixed user data from FIT files not being read from the Edge 800
Fixed error when removing user data from a list or list folder
Fixed error when using Trip Planner
Fixed error when selecting a track to create an Adventure from.
Horst G
Mopped(s): K 1200 LT MÜ 06/2005
#32 Beitrag von Horst G »
Version für 4.2.4 für MAC ist ebenfalls verfügbar.
Basecamp, Einstellungen, Software-Update
Gruß Horst
„Zwei Dinge sind unendlich, das Universum und die menschliche Dummheit, aber bei dem Universum bin ich mir noch nicht ganz sicher.“
-Albert Einstein-
#33 Beitrag von Frank@Pfalz »
ergänzend noch der Link zum BC 4.2.4 für MAC :wink:
Lumi
#34 Beitrag von Lumi »
Welche Funktion sinnvoll gewesen wäre.
Wenn man die Ränder/Ecken angeht zum verschieben im bearbeiten Modus dann entstehen die Pfeile die man anklicken muß. Diese müssen teils 10x angeklickt werden wenn man den Maßstab beibehalten will. Einmal drücken und halten für ein Scrollbertieb wäre da eine Erleichterung.
GS 2015
Philipp
Skype: fatalerrorlein
Mopped(s): R1200GS Rallye
#35 Beitrag von Philipp »
ich mach es mit den Pfeiltasten auf der Tastatur. MIt der linken Hand an der Tastatur und mit der Maus Wegpunkte setzen.
-Alles andere ist kein Hobby!
Lumi
#36 Beitrag von Lumi »
Deshalb hab ich das geschrieben weil es immer jemand gibt der was weiß :D
Ich versuchs auch mal so. Danke.
GS 2015
#37 Beitrag von bmw peter »
"ich mach es mit den Pfeiltasten auf der Tastatur. MIt der linken Hand an der Tastatur und mit der Maus Wegpunkte setzen."
Zum zoomen dann noch die Scrolltaste benutzen.
#38 Beitrag von Frank@Pfalz »
Update auf Basecamp 4.2.5 (für Windows) ist verfügbar
BaseCamp 4.2.5 ist als Update verfügbar ( innerhalb von BaseCamp über --> Hilfe --> nach Software-Updates suchen)
oder als Download über >> diesen Link <<.
GARMIN hat geschrieben:Changes made from version 4.2.4 to 4.2.5:
Fixed strings being displayed in multiple languages in the UI
Fixed long delay when changing the activity profile of a route on the route dialog
Fixed long delay when converting a track into a route
Fixed issue where changing the activity profile of an individual route leg wasn't applied unless one of the via times was also changed
Fixed issue clicking Next on the geotagged photo properties dialog when there is only one photo in the list
Fixed long delays when selecting many points in the track point list
Fixed long delays when pasting many points in the track point list
Improved robustness of auto-saving user data
#39 Beitrag von Frank@Pfalz »
Update auf Basecamp 4.3.3 WIN / 4.3.1 MAC ist verfügbar
BaseCamp ist als internes Update verfügbar (BaseCamp: Hilfe --> nach Software-Updates suchen)
oder als Download
WINDOWS :arrow: http://www8.garmin.com/support/download ... sp?id=4435.
MAC....... :arrow: http://www8.garmin.com/support/download ... sp?id=4449
GARMIN hat geschrieben:Changes made from version 4.3.2 to 4.3.3:
Fixed issue when importing a file and errors or warnings are encountered in the file
Fixed issue with adding or editing an activity profile
Fixed issue with changing the cover photo of an Adventure
Fixed issue when joining tracks
Changes made from version 4.3.1 to 4.3.2:
Fixes for several startup issues
Fixed error after ejecting a device
Fixed the Device Transfer Options page not being enabled
:!: BaseCamp 4.3.3 läuft erst ab Windows Vista SP2 :!:
alle älteren Betriebssysteme verwenden bitte weiterhin die Version 4.2.5
Ludwig45
Mopped(s): K 1600 GT
#40 Beitrag von Ludwig45 »
Hallo Frank.
habe gerade versucht das Update zu installieren. leider kann ich BC nicht mehr starten es kommt immer die Fehlermeldung
"Das Programm kann nicht gestartet werden. da MSVCR90.dll auf dem Computer fehlt. Installieren sie das Programm erneut, um das Problem zu beheben"
Das hab ich jetzt ein paarmal versucht, aber BC geht nicht zum starten und die Fehlermeldung erschein erneut.
Kannst Du mir da helfen?
liebe Grüße aus der grünen Mark
Ludwig :D
Fahre nie schneller als Dein Schutzengel fliegt!
#41 Beitrag von Frank@Pfalz »
Basecamp deinstallieren und nochmals installieren hat nun schon bei mehreren zum Erfolg geführt ;-)
ein "registryclean" nach der deinstallation schadet nicht.
Lumi
#42 Beitrag von Lumi »
Bei mir gings auch nicht gleich wegen Fehlermeldung.
Musste auch über Systemsteuerung deinstallieren und dann neu starten.
Jetzt läuft es, war aber die ganze Aktion nicht wert, kann kein Unterschied feststellen.
GS 2015
#43 Beitrag von Frank@Pfalz »
oh doch, es gibt einige Unterschiede.
z.B. ist eine Plaung mit Profil "kurvenreiche Strecke" nun auch in BaseCamp möglich.
Änderungesliste von V4.2 auf 4.3:
Added waypoint categories to the waypoint and bulk waypoint property dialogs
Added the Task Based Startup Menu allowing users to choose what they want to do giving more help into what BaseCamp can do
Added an Address search UI that operates more like MapSource
Added Find Intersection to the Find menu
Added richer context menus in most tools on the map
Added feature to calculate a route that tries to match the shape of a track
Added feature to optimize routes within trip planner
Added a way to make it easier to find recently downloaded BirdsEye imagery
Added a way to filter Adventures by activity when using Find
Added indication of Adventure selected on the map
Added display of route stats while editing the route on the map
Added display of track stats while editing the track on the map
Added a device information dialog
Added support for curvy road route calculation
Added 'snap to' indicator on the map when drawing new points in a route
Added ability to exclude track portions in the track join dialog
Added an 'Off Road' profile and clarified the difference between Off Road and ATV
Added a prompt to preserve the original tracks when joining tracks
Added a hotkey to open and close the overview map
Added elevation statistics to the route dialog
Added statistics display to the bulk route properties dialog
Added ability to remove shaping points from routes in the data list
Added display of rubber band when moving a waypoint on the map
Added display of state and country city search results
Added ability to create lists in the 'Send To' dialog
Added an 'uncheck all' option when managing Custom POIs
Added support for Lat/Lon coordiantes that are missing cardinal direction indicators
Added a comment column for tracks in the data list
Added more descriptive messages if export errors are encountered
Added FIT file support to the Import dialog
Improved performance when device maps are discovered for the first time
Improved address search on device or card maps
Improved balloons on the map
Improved drawing performance of large tracks and routes
Improved performance of filtering a track
Improved waypoint search performance
Improved discoverability of Adventure Edit, Publish, and View Online actions
Improved display of individual track portions in the track join dialog
Improved device communications performance when transferring photos
Improved notification that a subscription is needed for a selected BirdsEye product
Improved recovery from corrupted cache information from device maps
Simplified default toolbar layout to exclude some editing tools
Changed the map product selection combobox to be hidden in the default layout
Fixed issue with encrypted Custom POI search (for RV and dezl devices)
Fixed issues with routes that have multiple transportation modes
Fixed device calculated ascent and descent values not being displayed
Fixed Trip Planner crash when adding food stops to trips
Fixed Basestation not updating most recent update time for contacts
Fixed issue with reading photo waypoints that had missing photos
Fixed map points remaining on the map after turning off all points
Fixed Adventure playback not taking track speed into consideration
Fixed a possible error when creating backup files
Fixed issue with inverted routes maintaining previous departure times
Fixed various language translations
Removed printing restriction for card and device based map products.
#44 Beitrag von bmw peter »
Vor meinem Urlaub in 2 Wochen mache ich garantiert keine Experimente. :roll:
#45 Beitrag von Frank@Pfalz »
Peter, bist halt schon ein Fuchs ;-)
Lumi
#46 Beitrag von Lumi »
Dann weiß ich nicht was installiert wurde nach dem Hick Hack.
Kurvenreiche Streckenauswahl hab ich nicht.
Ps habs gefunden :D
ist auch 4.3.3 :!:
Schade das mein Datenmüll auch in "Meine Sammlung" wieder dabei ist. Aber das Problem kennt keiner.
GS 2015
#47 Beitrag von Frank@Pfalz »
Lumi hat geschrieben:Schade das mein Datenmüll auch in "Meine Sammlung" wieder dabei ist. Aber das Problem kennt keiner.
Nö, welchen Datenmüll meinst Du? Mach mal nen Screenshot.
btw: als erstes solltest Du eine Datensicherung (Datei->Sicherung erstellen) machen,
bevor Du mit anderen Aktionen beginnst...
Lumi hat geschrieben:Kurvenreiche Streckenauswahl .... habs gefunden :D
**thumb up**
ich habe ein zusätzliches Profil für diese Planungsart angelegt,
dann kann ich zwischen "Motorrad" und "Kurvenreich" umschalten ....
#48 Beitrag von bmw peter »
Lumi hat geschrieben: Schade das mein Datenmüll auch in "Meine Sammlung" wieder dabei ist. Aber das Problem kennt keiner.
Hast du denn mal den Filter geöffnet und die 4 oder 5 Rubriken angeklickt :?:
Wenn da deine ungewünschten Punkte erscheinen, sollten die auch da zu löschen sein. Glaube ich. :?
Lumi
#49 Beitrag von Lumi »
Schon aufgefallen hier fehlt der Punkt für ein Softwareupdate.
GS 2015
tommes66
Mopped(s): R1200GS Rallye, vorher R1200R
#50 Beitrag von tommes66 »
Frank@KS hat geschrieben:oder als Download
Danke Frank
tommes66 http://www.smilies.4-user.de/include/Fa ... ar_141.gif
Am liebsten immer eine handbreit Asphalt unter´m Reifen !
