Neue GARMIN Express Version
- BeeMWe
- Mopped(s): R1100 RT, R1200 RT LC
Re: Neue GARMIN Express Version
Hallo, jetzt
v 6.13.0.0
zur Verfügung.
v 6.13.0.0
zur Verfügung.
es grüßt
Gerald bzw. SieGer
kommt aber von Siebert, Gerald, weil mich Mama und Papa damals eben genau so nannten.
Gerald bzw. SieGer
GARMIN hat geschrieben:Garmin Express v6.13.0 for the PC includes the following changes:
- For our devices that support SD cards, we’ve added a second storage meter to the Tools & Content page.
....This will display the used and remaining free space of an SD card that’s inserted into the device.
- Users with ANT devices can now select the Continue button to download a firmware update.
- Map updates should no longer fail for Australia/New Zealand devices with the TopoActive AU/NZ map.
- Other minor bug fixes and improvements.
GARMIN hat geschrieben:Garmin Express v6.13.0 for the Mac includes the following changes:
- Lumi
GARMIN hat geschrieben: PC only V6.13.1:
--> Addressed an issue causing a high number of map update failures.
- BeeMWe
Hallo, jetzt
v 6.14.1.0
zur Verfügung.
v 6.14.1.0
zur Verfügung.
es grüßt
Gerald bzw. SieGer
Gerald bzw. SieGer
Garmin Express hat geschrieben: v6.14.1 for Windows includes the following changes:
- We fixed a bug that would prevent users from being able to add their device in Express if they received an error modal, “Could not save Nickname.”
- Corrected a screen orientation issue if a right-to-left language was set on the computer.
- We have re-implemented the storing of .fit and .tcx files from ANT devices locally on the user’s machine.
Garmin Express hat geschrieben: v6.14.1 for Mac includes the following changes:
- Users could run into an authentication issue when attempting to sign into their Garmin Connect account.
.....We’ve made some changes around the keychain to help alleviate this.
- Added language support for Chinese (Traditional-Taiwan).
- Lumi
- BeeMWe
es grüßt
Gerald bzw. SieGer
Gerald bzw. SieGer
- KlausRS
Ich hab da mal ne Frage: man ist ja heutzutage im Beruf und im Privaten von einer Vielzahl von Programmen begleitet und überall gibt es Updates.
Aber diese Vielzahl von doch kurz hintereinander folgenden Updates bei GE sind außergewöhnlich. Haben die keinen Plan oder woran liegt es.
Weiß einer die Lösung?
Schönen Vatertag, auch den Muttis:
Klaus
Klaus
Wie schnell ist nichts getan
Hey Klaus,
das liegt daran, dass die gesamte Gerätepalette von Garmin über das eine Programm upgedated wird.
Bei jedem neuen Gerät muss das funktionieren und auch bei den "outdated".
Daher kommen die Updates häufiger. Falls es Infos zu den Updates gibt,
stehen die ja hier und Du kannst entscheiden ob Du updatest.
Du musst nicht jedes Update mitnehmen; wenn Du deine Karten erneuertst, solltest Du vorher Express mitupdaten.
Oft enthalten Updates auch sicherheitsrelevante Änderungen. Daher wirst Du bei Windows 10 auch nicht gefragt,
sondern es wird auch ohne deine Zustimmung upgedated.
- KlausRS
Hallo Frank,
Dank Dir für die Aufklärung. Hatte mich nur gewundert, weil erstmal augenscheinlich doch ungewöhnlich.
Klaus
Klaus
- Lumi
Garmin Express v6.15.0 for PC
This version includes the following changes:
- Lengthened the character limit restriction for longer email domains.
- Improved messaging for an Express failure when a device does not have sufficient internal memory for a software update only.
Garmin Express v6.15.0 for MAC
- Fixed a crash that occur if a user were two double-click on the Add a New Device banner.
- Lumi
Garmin Express v6.16.0 for PC
Improved our map update operation, allowing the map to be copied over to the device more efficiently.
Garmin Express v6.16.0 for the Mac
Addressed two crashes that could occur at the launch of Garmin Express or after performing a required update of Garmin Express.
- BeeMWe
Danke für die Information.
es grüßt
Gerald bzw. SieGer
Gerald bzw. SieGer
v 6.16.0 für MAC scheint nicht zu funktionieren. Bei meinen beiden MACs wird jedesmal "Download fehlerhaft" angezeigt.
https://download.garmin.com/omt/express ... xpress.dmg
funktioniert (ich kanns halt nicht installieren
- Alt-Boxer
- Mopped(s): ehemals K 1200 RS
Der Download über die Update-Funktion(bei geöffnetem GE) funktioniert nicht - ist bei meinem Mac schon seit längerem so; der von Frank vorgeschlagene Weg über den Downlad des kompletten Installers (quasi eine Neuinstallation) klappt.
Ist ein wenig umständlicher, aber besser als immer wieder Zeit mit wiederholten Update-Versuchen zu verschwenden!
Hallo Alt-Boxer,Alt-Boxer hat geschrieben: ↑19. Juli 2019, 09:46 Der Download über die Update-Funktion(bei geöffnetem GE) funktioniert nicht - ist bei meinem Mac schon seit längerem so; der von Frank vorgeschlagene Weg über den Downlad des kompletten Installers (quasi eine Neuinstallation) klappt.
danke für den Tip. Hat geklappt. Bisher ging es bei mir immer über die update Funktion, wer weiß, warum jetzt nicht. Aber egal.
- Lumi
- BeeMWe
es grüßt
Gerald bzw. SieGer
Gerald bzw. SieGer
- Steinhuder
- Mopped(s): Earl Grey
- qtreiber
unter Windows habe ich mit GE noch nie Probleme gehabt.
Warte aber nach einem Update gerne ein paar Tage bis ich dieses installiere. Dies gilt noch mehr für Basecamp- (belasse ich bei Version 4.6.2) und Kartenupdates. Nie direkt vor einer größeren Tour und bereits dafür geplanten Routen.
- BeeMWe
Hallo, jetzt
v 6.17.0.0
zur Verfügung.
v 6.17.0.0
zur Verfügung.
es grüßt
Gerald bzw. SieGer
Gerald bzw. SieGer
