Neue GARMIN Express Version
BeeMWe
Mopped(s): R1100 RT, R1200 RT LC
Re: Neue GARMIN Express Version
#426 Beitrag von BeeMWe »
Hallo, jetzt
v 6.13.0.0
zur Verfügung.
:wink:
es grüßt
Gerald bzw. SieGer
kommt aber von Siebert, Gerald, weil mich Mama und Papa damals eben genau so nannten.
#427 Beitrag von Frank@Pfalz »
GARMIN hat geschrieben:Garmin Express v6.13.0 for the PC includes the following changes:
- For our devices that support SD cards, we’ve added a second storage meter to the Tools & Content page.
....This will display the used and remaining free space of an SD card that’s inserted into the device.
- Users with ANT devices can now select the Continue button to download a firmware update.
- Map updates should no longer fail for Australia/New Zealand devices with the TopoActive AU/NZ map.
- Other minor bug fixes and improvements.
GARMIN hat geschrieben:Garmin Express v6.13.0 for the Mac includes the following changes:
Lumi
#428 Beitrag von Lumi »
Jetzt
v 6.13.1.0
GS 2015
#429 Beitrag von Frank@Pfalz »
GARMIN hat geschrieben: PC only V6.13.1:
--> Addressed an issue causing a high number of map update failures.
BeeMWe
#430 Beitrag von BeeMWe »
Hallo, jetzt
v 6.14.1.0
zur Verfügung.
es grüßt
Gerald bzw. SieGer
#431 Beitrag von Frank@Pfalz »
Garmin Express hat geschrieben: v6.14.1 for Windows includes the following changes:
- We fixed a bug that would prevent users from being able to add their device in Express if they received an error modal, “Could not save Nickname.”
- Corrected a screen orientation issue if a right-to-left language was set on the computer.
- We have re-implemented the storing of .fit and .tcx files from ANT devices locally on the user’s machine.
Garmin Express hat geschrieben: v6.14.1 for Mac includes the following changes:
- Users could run into an authentication issue when attempting to sign into their Garmin Connect account.
.....We’ve made some changes around the keychain to help alleviate this.
- Added language support for Chinese (Traditional-Taiwan).
Lumi
#432 Beitrag von Lumi »
Jetzt
v 6.14.2.0
GS 2015
BeeMWe
#433 Beitrag von BeeMWe »
Lumi hat geschrieben: 29. Mai 2019, 20:27 Jetzt
v 6.14.2.0
.... Danke.
:wink:
es grüßt
Gerald bzw. SieGer
KlausRS
Mopped(s): R 1200 RS, XJR 1300
#434 Beitrag von KlausRS »
Ich hab da mal ne Frage: man ist ja heutzutage im Beruf und im Privaten von einer Vielzahl von Programmen begleitet und überall gibt es Updates.
Aber diese Vielzahl von doch kurz hintereinander folgenden Updates bei GE sind außergewöhnlich. Haben die keinen Plan oder woran liegt es.
Weiß einer die Lösung?
Schönen Vatertag, auch den Muttis:
Klaus
Wie schnell ist nichts getan :wink:
#435 Beitrag von Frank@Pfalz »
Hey Klaus,
das liegt daran, dass die gesamte Gerätepalette von Garmin über das eine Programm upgedated wird.
Bei jedem neuen Gerät muss das funktionieren und auch bei den "outdated".
Daher kommen die Updates häufiger. Falls es Infos zu den Updates gibt,
stehen die ja hier und Du kannst entscheiden ob Du updatest.
Du musst nicht jedes Update mitnehmen; wenn Du deine Karten erneuertst, solltest Du vorher Express mitupdaten.
Oft enthalten Updates auch sicherheitsrelevante Änderungen. Daher wirst Du bei Windows 10 auch nicht gefragt,
sondern es wird auch ohne deine Zustimmung upgedated.
KlausRS
#436 Beitrag von KlausRS »
Hallo Frank,
Dank Dir für die Aufklärung. Hatte mich nur gewundert, weil erstmal augenscheinlich doch ungewöhnlich.
Klaus
Lumi
#437 Beitrag von Lumi »
Jetzt
v 6.15.0.0
GS 2015
#438 Beitrag von Frank@Pfalz »
Garmin Express v6.15.0 for PC
This version includes the following changes:
  • Lengthened the character limit restriction for longer email domains.
  • Improved messaging for an Express failure when a device does not have sufficient internal memory for a software update only.
  • Other minor bug fixes and improvements.
Garmin Express v6.15.0 for MAC
  • Fixed a crash that occur if a user were two double-click on the Add a New Device banner.
Lumi
#439 Beitrag von Lumi »
Jetzt
v 6.16.0.0
GS 2015
#440 Beitrag von Frank@Pfalz »
Garmin Express v6.16.0 for PC
Improved our map update operation, allowing the map to be copied over to the device more efficiently.
Garmin Express v6.16.0 for the Mac
Addressed two crashes that could occur at the launch of Garmin Express or after performing a required update of Garmin Express.
BeeMWe
#441 Beitrag von BeeMWe »
Danke für die Information.
:wink:
es grüßt
Gerald bzw. SieGer
TanSri
#442 Beitrag von TanSri »
v 6.16.0 für MAC scheint nicht zu funktionieren. Bei meinen beiden MACs wird jedesmal "Download fehlerhaft" angezeigt.
#443 Beitrag von Frank@Pfalz »
https://download.garmin.com/omt/express ... xpress.dmg
funktioniert (ich kanns halt nicht installieren :oops:
Alt-Boxer
Mopped(s): ehemals K 1200 RS
#444 Beitrag von Alt-Boxer »
Der Download über die Update-Funktion(bei geöffnetem GE) funktioniert nicht - ist bei meinem Mac schon seit längerem so; der von Frank vorgeschlagene Weg über den Downlad des kompletten Installers (quasi eine Neuinstallation) klappt.
Ist ein wenig umständlicher, aber besser als immer wieder Zeit mit wiederholten Update-Versuchen zu verschwenden! :evil:
TanSri
#445 Beitrag von TanSri »
Alt-Boxer hat geschrieben: 19. Juli 2019, 10:46 Der Download über die Update-Funktion(bei geöffnetem GE) funktioniert nicht - ist bei meinem Mac schon seit längerem so; der von Frank vorgeschlagene Weg über den Downlad des kompletten Installers (quasi eine Neuinstallation) klappt.
Hallo Alt-Boxer,
danke für den Tip. Hat geklappt. Bisher ging es bei mir immer über die update Funktion, wer weiß, warum jetzt nicht. Aber egal.
Lumi
#446 Beitrag von Lumi »
Jetzt
v 6.16.1.0
GS 2015
BeeMWe
#447 Beitrag von BeeMWe »
Lumi hat geschrieben: 26. Juli 2019, 14:49 Jetzt
v 6.16.1.0
Danke.
:wink:
es grüßt
Gerald bzw. SieGer
Steinhuder
Mopped(s): Earl Grey
#448 Beitrag von Steinhuder »
v 6.16.1.0
Und?
Geht jetzt die Update Funktion wieder?
Ich neige dazu, solche nachrangigen Dinge eher auszusitzen.
Muss ich jedes Update mitnehmen?
qtreiber
#449 Beitrag von qtreiber »
Steinhuder hat geschrieben: 27. Juli 2019, 08:19Geht jetzt die Update Funktion wieder?
unter Windows habe ich mit GE noch nie Probleme gehabt.
Warte aber nach einem Update gerne ein paar Tage bis ich dieses installiere. Dies gilt noch mehr für Basecamp- (belasse ich bei Version 4.6.2) und Kartenupdates. Nie direkt vor einer größeren Tour und bereits dafür geplanten Routen.
BeeMWe
#450 Beitrag von BeeMWe »
Hallo, jetzt
v 6.17.0.0
zur Verfügung.
:wink:
es grüßt
Gerald bzw. SieGer
