Neue GARMIN Express Version
Nachricht
Autor
TanSri
Mopped(s): R1200R LC, R1200RS LC
Re: Neue Garmin Express Version erhältlich
#351 Beitrag von TanSri » 28. März 2018, 09:14
Jetzt 6.3.0.0
Gruß von der Küste
Udo
BeeMWe
Mopped(s): R1100 RT, R1200 RT LC
#352 Beitrag von BeeMWe » 28. März 2018, 16:01
TanSri hat geschrieben:
Jetzt 6.3.0.0
Danke für die Info.
:wink:
es grüßt
Gerald bzw. SieGer
kommt aber von Siebert, Gerald, weil mich Mama und Papa damals eben genau so nannten.
Frank@S
Mopped(s): XR
#353 Beitrag von Frank@S » 28. März 2018, 16:38
Garmin hat geschrieben:Garmin Express v6.3.0 for PC.
This version includes the following changes:
Music files would not be included with the transfer of a playlist that was exported from iTunes. This was causing an error and has now been resolved.
Other minor bug fixes and improvements.
Garmin hat geschrieben:Garmin Express v6.3.0 for Mac.
Fixed an issue with Express not launching automatically when devices were being connected.
Lumi
#354 Beitrag von Lumi » 26. April 2018, 15:32
Jetzt
v 6.4.0.0
GS 2015
Frank@S
Mopped(s): XR
#355 Beitrag von Frank@S » 26. April 2018, 18:30
Garmin hat geschrieben:Garmin Express v6.4.0 for PC includes the following changes:
- Added the option to use your iTunes Library to manage music within Express.
- If a user backed up their favorites from an older Automotive device into Express,
the file would go to the incorrect location and not appear on the new device when it would get transferred.
We fixed this issue and now the file for your favorites will transfer to the correct location.
- Other minor bug fixes and improvements.
Garmin hat geschrieben:Garmin Express v6.4.0 for Mac includes the following changes:
- Fixed an issue with purchased downloadable content not appearing in the Purchased tab if the content had not been activated to a device yet.
Lumi
#356 Beitrag von Lumi » 6. Juni 2018, 14:29
Jetzt
v 6.5.0.0
GS 2015
BeeMWe
#357 Beitrag von BeeMWe » 6. Juni 2018, 15:21
Danke für die Info
:wink:
es grüßt
Gerald bzw. SieGer
Alpenbummler
#358 Beitrag von Alpenbummler » 6. Juni 2018, 21:25
Und eine neue Karte gibt's auch: 2019.10
Eines der letzten Updates hängt bei mir. Es wird mir dauernd angezeigt, aber trotz meiner Installation (und einer erfolgreichen Fertigmeldung) kommt das Update immer wieder:
Habt Ihr das auch?
Frank@S
Mopped(s): XR
#359 Beitrag von Frank@S » 6. Juni 2018, 21:51
ja, hab das auch; es wird die Ver 1,50 in GE angeboten, aber nur 1,40 installiert
wichtig ist, dass die 1,20 upgedatet wird; mit dieser funktionieren die Abbiegehinweise nicht
mit 1,40 schon.
Frank@S
Mopped(s): XR
#360 Beitrag von Frank@S » 6. Juni 2018, 21:57
Lumi hat geschrieben:
6. Juni 2018, 14:29
v 6.5.0.0
Garmin began rolling out Garmin Express v6.5.0 for the PC today.
Express indicates a new device has been connected by displaying a banner. Also, for users who have had to send in their device and received a replacement, Express will detect that it’s the same model of device and ask if you’d like to replace the already added device or add it as a new device.
Improvements have been made to the Help Pages for adding a device.
Fixed an issue that could cause the time to change on a Forerunner 645 after being synced.
Garmin began rolling out Garmin Express v6.5.0 for the Mac today.
For some of our fitness devices, Express would indicate a sync failure, even if an activity synced successfully. The sync failure will no longer appear unless it’s a valid failure.
Fixed an issue for our users with devices that have a microSD card slot. A failure would occur when attempting to install an update or downloadable content, regardless if it was to the internal memory or the microSD card.
nix Weltbewegendes...... :-)
hixtert
Mopped(s): BMW, BMW, Triumph
#361 Beitrag von hixtert » 7. Juni 2018, 05:45
Mir wurden gestern neue Karten angeboten, 2019.10. Die waren in 25min auf PC und zumo installiert.
Bei nochmaligem Anschluss des zumo wurden mir wieder die Karten angeboten. Vielleicht war beim Karten-Update was schief gegangen (Fehler konnte ich nicht feststellen), also habe ich noch einmal installiert.
Beim dritten anschließen kam auch das Angebot wieder.
Ich freue mich schon auf GE 6.6.0.0. :roll:
Unser WIKI
Lumi
#362 Beitrag von Lumi » 7. Juni 2018, 15:21
Jetzt
v 6.5.1.0
GS 2015
hixtert
#363 Beitrag von hixtert » 7. Juni 2018, 19:32
hixtert hat geschrieben:
7. Juni 2018, 05:45
7. Juni 2018, 15:21
Jetzt
v 6.5.1.0
... und der Karten-Update-Fehler ist beseitigt. :D
Unser WIKI
Lumi
#364 Beitrag von Lumi » 29. Juni 2018, 13:50
Jetzt
v 6.6.0.0
GS 2015
BeeMWe
#365 Beitrag von BeeMWe » 29. Juni 2018, 14:51
Jetzt
v 6.6.0.0
Danke für die Info.
Aber auch die neuen Karten 2019.10 für Zumo 660, sind zur Verfügung.
:wink:
es grüßt
Gerald bzw. SieGer
Frank@S
Mopped(s): XR
#366 Beitrag von Frank@S » 29. Juni 2018, 21:00
Garmin Express V6.6.0.0 for PC.
If you’ve purchased a map from a vendor that contains a voucher code, the code can be redeemed through Express to activate and download the map.
It’s always best to keep Garmin Express up to date with the latest version. Express will now provide an alert when a new update is available.
..... This will allow you to know right away and not have to depend on going into the Settings to check for updates.
Garmin Express V6.6.0.0 for Mac
If you’ve purchased a map from a vendor that contains a voucher code,the code can be redeemed through Express to activate and download the map.
Fixed two issues with some of our earlier fitness devices, such as the Edge 305 and Forerunner 305.
These devices can be added to Express if you’re running 10.11.
Express would indicate a successful sync, but any activity on the device would not upload to Garmin Connect. The activities are uploading successfully now.
Achim1958
#367 Beitrag von Achim1958 » 9. August 2018, 08:00
neue Version
v 6.7.0.0
Frank@S
Mopped(s): XR
#368 Beitrag von Frank@S » 9. August 2018, 09:21
Achim1958 hat geschrieben:
neue Version 6.7.0.0
Garmin Express v6.7.0 for the PC includes the following changes:
- For our devices that support CIQ apps, you will no longer need to log into the CIQ Store when launching from Express.
- If you encounter a crash when using Express, we now provide you the ability to send us the crash report information right away. Receiving these reports will help us continue to improve your experience.
- We’ve made some improvements to music management with our supported devices. Express will display the amount of free space available on the device and the total size of all content you’ve selected to download.
- We improved our map update page by displaying the completed percentage and the download rate.
- For downloadable content, such as our Cycle Maps, not all the necessary files were being delivered. Users will receive all the correct files now and no longer receive a “Can’t Unlock Maps” message.
Garmin Express v6.7.0 for the Mac includes the following changes:
- We’ve made some improvements to music management for our supported devices. Express will display the amount of free space available on the device and the total size of all content you’ve selected to download.
BeeMWe
#369 Beitrag von BeeMWe » 10. August 2018, 12:55
hatte auch gleich die neue Version insatlliert, dieses mal soager mit Neustart.
Heute schau ich nach da ist wieder nur die alte Version 6.6.0.0 wieder drauf.
Wurde das zurückgezogen ???
es grüßt
Gerald bzw. SieGer
Achim1958
#370 Beitrag von Achim1958 » 10. August 2018, 16:22
nein bei mir ist immer noch die neue Version drauf.
Gruß Achim
BeeMWe
#371 Beitrag von BeeMWe » 10. August 2018, 20:16
habe Garmin Express komplett vom Rechner deinstalliert und neu installiert.
Jetzt wieder alles in Ordnung.
Das neue Update v. 6.7.0.0 ist jetzt wieder funktionsfähig.
:wink:
es grüßt
Gerald bzw. SieGer
BeeMWe
#372 Beitrag von BeeMWe » 15. August 2018, 15:36
nwu Version erhältlich:
v.6.7.2.0.
:roll:
es grüßt
Gerald bzw. SieGer
TanSri
#373 Beitrag von TanSri » 17. August 2018, 10:23
Kann es sein, dass die Version 6.7.2.0 nur für Windows ist? Bei meinem MAC wird nur 6.7.0.0 angeboten.
Gruß von der Küste
Udo
Frank@S
Mopped(s): XR
#374 Beitrag von Frank@S » 17. August 2018, 18:32
Garmin hat geschrieben:We’ve released a hotfix for Garmin Express (Windows only)
6.7.2.
Fixed an issue with the installer. Any new users who had never installed Express before would encounter an error during the installation.
6.7.1
Fixed a crash that would occur after updating Express to v6.7.0. The crash happens when the user tries to launch Express.
mportant Notes:
If you have updated to v6.6.0 or v6.7.0, but are able to launch Express successfully, you are not impacted by this issue. We still highly recommend updating, however.
If you have updated to v6.7.0, and are experiencing the crash, you must download Express from our website: http://www.garmin.com/express
You do not have to uninstall Express before downloading from the website.
TanSri
#375 Beitrag von TanSri » 17. August 2018, 20:50
Danke Frank.
Gruß von der Küste
Udo
Mitglieder in diesem Forum: 0 Mitglieder und 0 Gäste
