How to read the motronic 2.4 fault code?
Jo_
#1 Beitrag von Jo_ »
Hello...
Code: Alles auswählen
A) The K1200RS ('97) real wiring:
! Motronic !
!    18 DL !------------(Light)------------ + Batttery
!          !                                  ( +12V )
(Light) is the dashobaord water temperature warning light.
B) What I understand, many do that (with sucess):
(See on the Dutch page, the K1200rs forum...)
! Motronic !
!          !            ! Switch
!    18 DL !-------+--o   o--+------------- - Batttery
!          !       !         !                (Ground)
!          !       +--<LED>--+
<LED> is a LED (with a resistance).
Setup: instead of the warning light, put a wire to the (-) pole
with a switch and a LED according to this diagram.
a - start the engine
b - press the switch for 5 secondes
c - wait for flashes ( [1-4][1-4][1-4][1-4] code).
d - "goto" (b) to get the new code.
Does-it work?
Can you confirm?
C) Using the warning light instead of a LED (or voltmeter):
(See K11 site)
! Motronic !
!          !     Switch  o---(Light)------ + Batttery
!          !----------o/
!    18 DL !
!          !             o---------------- - Batttery
!          !                                 (Ground)
With the same procedure(a,b,c,d,...)
Can I do that?
Can it work?
D) Simple method to erase the default codes:
Just unplug the battery for a while, no?
Sources and links:
Motronic K11:
http://www.geocities.com/fwarner_au/mc_things/K_fuel_injection.html
Put the pin #1 (diagnostic connector, motronic #20 ) to ground,
and the motronic will send the data though his pin #20 (temp. warning light).
Wiring diagram K12rs:
http://www.whitepond.org/ibmw/wire_diagrams/
About the "VI" 6:
I (ME) understand that the diagram is wrong about the warning light:
- one wire go to the pin #18 (H9001-A9001-X9022-A9500
- one wire go to ground (H9001-A9001-X9022-X9231-G9230) FALSE !!!!
=> I found +12V on this wire!
Diagnostic Box: GERMAN
http://www.k1200rs.de/faq/diagnosebox/diagnosebox.html
Note: The first PDF show that the warning light go to the + pole.
Motronic uitlezen en reseten: DUTCH
http://www.bmwgsclub.nl/motronic-reset.html
K1200RS Forum: GERMAN
http://www.bmw-bike-forum.info/k1200rs/
Thanks !!!!
Pezi
Re: How to read the motronic 2.4 fault code?
#2 Beitrag von Pezi »
Jo_ hat geschrieben:Hello...
Rehello Jo, sorry just read your article/question/answer? ;)
I did it with:
1 LED
1 Resistor 560 Ohm
1 push button
1 plug for the board socket
Works great :) :)
Jo_
#3 Beitrag von Jo_ »
So....
Does-it mean the wiring diagram & procedure "B" are correct ?
Thanks again,
Jo
