BETA !!! Software update GPSmap 276c
Ralph
Mopped(s): K1200LT - R1150GS
#1 Beitrag von Ralph »
Hallo 276c Nutzer,
es gibt bei garmin ein Update der Firmware für den 276c:
http://www.garmin.com/support/agree.jsp?id=622
hier die Neuerungen:
*********** Please Note! *************
This is BETA software. Although this software is believed to be reliable,
it has not yet been released for production and should be used at your own risk.Changes made from version 2.70 to 2.93:
* Added support for remote sonar.
* Added marine DSC support.
* Added altitude to the active track and saved tracks.
* Increased number of proximity waypoints to 100.
* Added calendar pages (day, week, and month) to the Main Menu.
* Added column titles to the Add/Edit Vias page.
* Added option to Point Review pages to 'add to current route' when navigating an auto-route.
* Added options to Volume/Light Control page to go to Sound or Display setup menus.
* Added auto backlight adjustment based on sunrise and sunset.
* Added 'voice prompt' option to Sound setup; user now has ability to limit or prevent voice prompts.
* Added output rate configuration to the Advanced NMEA Setup page.
* Added support for non-U.S. time zones.
* Added GPS status to the list of configurable data fields.
* Added support for selecting active track color.
* Added choice to 'routes setup' to transition waypoints by distance when navigating a manual route.
* Fixed highlight movement bug on Proximity Waypoints page.
* Added 'custom avoids' and 'custom road preferences' to Road Routing setup.
* Changed Data Card Information page into Map Information page to include version information for all map data (basemap).
* Fixed 'hide/show all' options on the Map Information page.
* Fixed 'lock to road' option so unit remembers user's changes to it.
* Popup text on the Map page is positioned to avoid appearing under the cursor.
* Fixed problem preventing user from editing the elevation of user waypoints.
* Added ability to move waypoints in active manual routes.
* Enabled odometer as a configurable field in Marine mode.
* Fixed address searches so number field will show all valid characters.
* Enabled track log recording in simulator mode.
* Fixed issue with Map setup that prevented the user for changing the Marine navaid symbol set.
* Added support for auto CDI scale setting.
* Modified Route List page to indicates an active route with an icon to the left of the route name.
* Added new distance and speed unit, nautical (nm, kt, m).
* Fixed shutdown when clearing active track log.
* Fixed TracBack operation for large tracks.
* Added marine timer as a page layout for the Compass page.
* Fixed functionality of deleting waypoints by category.
* Added blank configuration field for 'map with overlay' layout.
* Fixed issue with Indonesian southern grid being located in the wrong area.
* Updated language translations.
* Fixed issue with displaying BlueChart data without water color.
* Added carpool lanes to avoid options in Road Routing setup.
ich denke da ist für jeden 276c User einiges neues bei.
Gruß Ralph
Ralph
erste Eindrücke...
#2 Beitrag von Ralph »
Hi 276er User,
einen Sack voll neuer Funktionen und Erweiterungen. Man kann jetzt sogar Straßen angeben, die man im Routing vermeiden will, weil da z.B. temporär eine Baustelle ist, etc. Mann kann jetzt ein Strassenprofil einstellen, in dem man per Schieberegler die Präferenzen für einzelne Strassentypen bestimmen kann. Sommer/Winterzeitumstellung geht jetzt automatisch und die Einstellung anderer Zeitzonen muß nicht mehr per UTC +/- Abweichung angegeben werden. Es ist soviel, da muß man sich erstmal eingehend mit beschäftigen.
Die Übersetzungen einzelner Funktionen ist jetzt besser eingedeutscht, dafür sind alle neuhinzugekommenen Funktionen noch alle in Englisch, also ein echter deutsch/englischer Mischmasch, das führe ich aber auf den noch BETA-Status der Software zurück.
ACHTUNG alle Userdaten und Einstellungen werden mit dem aufspielen der neuen Firmware gelöscht.....!!!!!
Gruß Ralph
Ralph
Beta 2.94 ist raus
#3 Beitrag von Ralph »
Hallo Die Beta 2.94 für den 276C ist da und korrigiert einige der Fehler der 2.93:
it has not yet been released for production and should be used at your own risk.Changes made from version 2.93 to 2.94:
* Fixed shutdown when attempting to view the map families via the Data Card Information page
* Corrected problem with on-route gotos.
* Fixed problem with autoroute icon not showing up for all saved autoroutes.
* Corrected problem with routes transferred from MapSource that show improper 'distance' and 'ETE' values.
* Fixed problem on the Active Route page that prevented the 'change data fields' option from working properly.
* Corrected the way the date is displayed on the Calendar page to be consistent with other pages.
* Fixed problem with display of the Find menu from the Month tab of the calendar.
* Fixed problem with TracBacks on large saved tracks.
* Improved backlight auto-adjustment feature; turned this feature off by default.
* Added standard European and Australian time zones.
* Fixed Daylight Savings to work correctly in the southern hemisphere.
* Turned off track recording for operation in simulator mode.
* Fixed shutdowns while driving in automotive mode without a route active.
* Fixed problem with entering dates on the Sun and Moon page.
* Fixed the point review page option 'Append To Route' to correctly add the point to the end of the selected route.
* Fixed problem with Edit Via page displaying the pointer improperly.
* Fixed shutdown when attempting to view the Log Filter tab on the main menu Message tab.
* Fixed problem with Calendar Day page not always displaying the items.
Gruß Ralph
